Ran the SR9 and the P95 through it so far, with some medical supply cleaning concentrate.
The cleaning concentrate isn't meant for grease, oil, or firearms at all, and it still did a rather fantastic job, all things considered.
The heavy build up of goo in the p95 didn't all come off (I bought it used) but the thing certainly looks clean. I was starting to get a little corrosion or something when I started to let it dry, so I rinsed it with water and blew it dry, oiled it up alittle, did my normal grease job, and reassembled.
It certainly looks cleaner.
The sr9 I field stripped and through in, and it made a huge difference as well. the frame is nearly spotless, including the grip checkering, the slide serrations, etc.
So far, so good.
So far, so good.
