Scott P, we got 12" in our yard ... but the depth varied all over the place around here ... and the drifting made it hard to measure in general.
The Ariens got an amusing little workout of about an hour. Worked great. The 12" of powder (temp was in the single digits) flew for 40 feet or more. I couldn't ask for more.
Looking at what I wrote above, my machine had what you might describe as a 'manufacturing defect' ... depending how you define the term. The pulley (a double) on the engine's main shaft had to be slid out about 3/16" so it would better match up with the belts on the rest of the machine ... and not shred them as was happening. I bet if this misalignment was any worse, it would have thrown belts under load, probably at the time of engagement and disengagement.
The hardes part of the job was breaking loose the two set screws that hold the double pulley in place. I felt like I was going to snap my allen wrench in half!
--- Bror Jace
PS - Is it just me or do these things really build up a lot of moisture in the crankcase? New oil has only 1 hour of run time on it and it's already got some milky residue all over the dipstick.
Is it the cold, unfiltered air and the moisture which gets sucked in through the carburetor?
--- Bror Jace
