Originally Posted By: Pop_Rivit
Originally Posted By: clarklawnscape
avoiding carb problems, rotted fuel lines, stiff diaphrams, not to mention minimal $50/labor charges, just to name a few. just seems as if youre LUCKY, so far that is. this is an argument that seems impossible to win, but go to your local dealer ope and ask for proof, theyll show you, and they dont sell gas, so there goes the trying to up-sale ya theory
If you maintain your fuel (E10) and your equipment then that's hogwash.
I run E10 in everything and have for 25-30 years. I keep the fuel maintained with Stabil, and haven't had a carb or fuel related issue in that time. I also have 4 Ford N tractors, two of which are trailer queens and only get run for an hour or so a year when taken to shows. Again, zero fuel/carb problems.
I pulled my chain saw out two weeks ago to trim some branches. It had been sitting for 8 months with E10 in it, and it started on the third pull and ran perfectly. My pressure washer, my DR trimmer, my rototiller and every other small engine all see E10 exclusively, and I've had zero problems.
Even my 1974 John Deere 210 has E10 in it. I only use it 2-3 times each year, and it has no fuel issues at all. Granted I rebuilt the carb on it when I pulled it out of storage, but it hadn't been run for almost 20 years. I would have rebuilt the carb on anything that had not been run in two decades.
I have rebuilt carbs for a number of friends, but it's because they didn't treat the fuel before letting something sit for an extended period. And quite often, it hasn't been E10 that was sitting in there.
And as far as my local dealer? It's a John Deere dealer, and they don't have an issue with E10 in anything they sell as long as it's treated with Stabil (just as any non-ethanol should be).
ITs far from hogwash, and you treat your fuel just as you should, thus making the difference in youre case. Ethanol WILL kill fuel lines and carbs in OPE if untreated. Most OPE fuel system parts are not recommended above 10% ethanol, and thats assuming the fuel is rated properly as well as the part/product. My posts are far from hogwash, and on this subjuct, it isnt simply an opinion.
