Kestas
Staff member
Originally Posted By: ecotourist
I hear comments about cheaper and better steel quite often. Old Volvos were said to be rust resistant because they were made of "good Swedish steel". At one point Japanese cars were said to rust because they were made of poor quality steel (with the second assertion that the steel was of poor quality because it was made from scrap steel - as if that would make a difference).
Calling any steel experts. Is rust resistance because of differences in steel quality or because of better coatings and more attention to design?
And if "better quality steel" is more rust resistant, what makes some steel better than others?
Humbleness aside, I am a steel expert. Plus, I've studied corrosion cases for the automotive industry.
There is no such thing as one steel being better than the other. Automotive bodies are typically made of 1008 steel, which is about as simple a steel as you can get before you have pure iron.
The differences are in the coatings. There are zinc, or zinc-rich coatings typically applied, phosphate, E-coat primer, color coat, and clear coat. I've studies dozens of varieties of zinc coatings. Some better, some worse. The presence and quality of these coatings will have an impact on corrosion resistance.
Even the best of coatings can be breached by a rock leaving a chip in the paint, which exposes the metal and continues with the onset of corrosion.
