My cousin's got a '07 TrailBlazer, which I just did a brake job on. I had the rotors resurfaced, as they were glazed, and installed a set of Raybestos Advanced Technology Ceramic pads before replacing the fluid. I bedded in the pads using the following technique:
- 6 x smooth stops from 35 MPH - 0 MPH
- 4 x smooth stops from 45 MPH - 0 MPH
- 2 x smooth stops from 65 MPH - 0 MPH
In all 12 stops, I did not stop the vehicle completely or allow the pads to "rest" on the discs.
Usually, during the process, I can smell the brakes. But this time was a slightly different experience. I could smell the rear brakes, but I literally had quite a bit of smoke coming out from front. I let the car sit for about 4 hours, and it took about 4-5 minutes before the smoke went away.
Having said that, the brakes now grab perfectly, and the rotors have a matt finish to them with a blue/gray tint. But this is the first time I've seen a bedding procedure result in so much smoke. That said, this is also the first time I try ceramic pads. Is this considered "normal"? Thanks!
Edit: Here's a video I filmed shortly after parking the vehicle. Not as much smoke as there was initially, but you can still see it. Video
