My 11 F150 has a sweet "phenol" type smell when you turn on the A/C. Much more pungent than PAG oil. I am not driving the truck for some repairs (so no A/C moisture) and if I go down everyday and turn the fan on it is there. After about 2 minutes, it is much weaker.
I did try some generic "lysol" thru the intake, but it did not really help (will try the real thing soon). This seems to be a common problem online, and can reoccur even with a new Ford Part. I did not hook manifolds up yet to check for leaks.
I also read the aftermarket Evaporators don't fit right. Anyone have experience with this? Seems in some cases it is a leak, in others just severe mildew building on an Evap with a bad coating.
