Smell of gasoline
Toronto
Hello
Since I bought the car I have smelt strange smell of gasoline when I check the oil.
I'm not very worried that there is a fuel leak in the oil becouse the level of oil doesn't rise.
Is it normal this smell ?
No. If you do a lot of highway driving you may be burning off any fuel leaking into the oil. You should get a used oil analysis to check for fuel contamination.
If the car has an underhood charcoal canister, the canister can be contaminated with fuel from someone overfilling the tank.
Originally Posted By: H2GURU
Giving the vehicle type will yeild an answer that may be closer to target?
Yes you are rigth
is Kia spectra 2006
Yes I'll do for sure next oil change
Kia has definetly come a long way, I remember back in 1974 my Dad got me a 3 speed bike for Christmas, I remember I wanted a 5 speed Schwinn and ended up with a 3 speed Kia. If the cars are as good as the bikes you should get a lot of miles out of this car, good luck with finding where the smell of gasoline is coming from.
Anyway the best thing is to make and UOA next oil change and I will see if there is gasoline in the oil.
The car goes good especially from the last oil change when I put petrol canada synthetic oil instaead the oil of kia dealer.
But the smell didn't go away I thougt that was the kia dealer oil to have that smell.
Originally Posted By: mechtech2
Where is the oil smell coming from?
From under the hood in general, or specifically from something when you check your oil?
The smell comes from the oil, I smell the oil on the cloth that i used for wipe the dipstick of oil.
Originally Posted By: cmhj
Almost sounds like an engine that is short tripped a lot and seldom warmed up fully.
not correct most of kilometeres are on high way and we warm the car for at least 2 minutes, 4 in the winter
