Smallest oil capacity?
San Francisco Bay Area
When I was changing the oil in my wife's 2002 Honda Civic LX, I was thinking of how little oil was being used. The manual says the change amount is 3.4 quarts with a filter, and 3.2 quarts without a filter. I'm not going every other oil change without changing the filter, but I'm thinking some actually follow that recommendation.
It seems like barely enough oil. I've serviced the oil on some cars that were around 4 quarts, even with smaller displacement engines. The first time I bought oil for this car was a 5 quart jug of Pennzoil 5w20 conventional. For that I had to find an empty bottle and write down what I put in there. I needed the jug to store the used oil.
Anything fairly recent that uses even less oil than this?
The first generation X-Terra with a V6 only used 3 or 4 quarts. It was designed to tow and go off road. Oddly, you don't hear of too many oil related engine failures with X-Terras. Go figure.
Wow those are really small amounts. My old Mercedes ML320 used to take 8.5 qts of required synthetic
I have a Nissan Murano and it has a 3.5 liter V6 with a 4.3 quart capacity.
In contrast, my Buick Enclave with a 3.6 liter V6 has a 6.5 quart capacity!
Originally Posted By: SLCraig
The 1.8L Sentra uses something like 3 quarts. I don't know of any sump smaller, although its definitely possible.
They've upped it to 4.2 quarts on the new ones, but yeah, some 7-10 years back, it was 2.9 qt.
In line with the Xterra, the old Nissan V6 4x4 trucks held less than 3.5 quarts, I think it was a 3.0 liter motor. That always surprised me.
this is not the smallest oil capacity but maybe the smallest capacity per cubic inch. I drove a Cadillac Eldorado in 1977 that had a 500 CID V/8 and it held just 5 quarts of oil! I believe that was with filter.
The Civic that I had held 3.5 quarts w/ filter. My dad's van with the Nissan VG33E holds 3.5 quarts. I don't like leftover oil so I round up and put in the extra .5 quart and never had a problem.
There are so many cars that don't take anywhere close to five quarts that there probably little correlation between oil capacity and engine longevity if the engine was properly designed and regular oil changes are done.
