Just changed the oil in my '98 3.0L Caravan 55k mi, and after adding just under 4 quarts, I checked the level, and it's reading about a quart HIGH!? I also changed the filter and filled it with oil before installing. Ran it for a bit to get it up to operating temp and it still reads way high. It is parked on a level surface. According to the owners manual and the chiltons guide, it should take 4.5 quarts with a filter change. All I can think of is there is so much sludge in the oil pan /engine that it's taking up oil volume. But more than a quart and a half? That's a lot of crud. Looking in the oil fill hole in the valve cover, I can see some varnish on the top end parts, but it doesn't look too bad. Anyone else have this problem? I just got the van a couple of weeks ago and don't know about the maintenance history, although it was originally a rental vehicle. I would assume they would keep up on the maintenance.
SoF
SoF
