Originally Posted By: d00df00d
Pretty sure they're all gears nowadays. Never heard of a belt in a remotely modern transaxle (except in some kinds of CVTs).
Lots of AWD transaxles have a transfer belt. The last FWD-only belt application I remember is the Chrysler LH series (42LE transaxle)- because it had a longitudinally-mounted engine and were designed with an AWD option in mind that was never built.
The 42LE was almost identical to the 41TE (transverse engine version), but the TE used an idler shaft instead of a transfer chain and a helical gear differential instead of a hypoid. The newer FWD Mopars are all CVT, so the 41TE (still used in the PT Cruiser) will probably be the last conventional FWD transaxle for Mopar.
