Quote:
GF-4 is the fuel efficiency spec. German Castrol doesn't meet it either (I think). In order to meet the GF-4 spec, your 30wt viscosities will be on the low end of the scale and I assume this is why Amsoil ASL/ATM/TSO are now low 30wt oils. As an OEM fill, this is why M1 was always towards the low end.
It's interesting to know that ZDDP doesn't help with Al piston skirts. I've had a few people tell me they think Redline is a bit outdated in their formulation approach for modern engines due to the high levels of ZDDP. I'm waiting for a response from Dave as to why they don't make their street oils more API compliant. Reasong being, we have seen modern SM oils perform extremely well in all conditions that the need for high levels of ZDDP don't benefit the majority of engines out there now. Am I correct on this?
I would guess that a lot of the racing crowds, using older technology as 427 stated, still will need the extra ZDDP. However, 99% of us don't anymore. Other additives seem to be doing an outstanding job, like Boron for instance. People that buy RL for the ZDDP levels and POE base might never see the benefit simply bc the engine design doesn't all for an oil formulated that way.
People have knocked the API on this site, but IMO, it has improved the quality of oil to meet the demands of today's modern engines. It's forced oil companies to look for alternatives to ZDDP. As TeeDub said, if Amsoil felt these newer additives didn't do the job, they probably wouldn't use them.
