Long Long time to get the results.
Went to Analyst's Inc, and came back
"The VARNISH POTENTIAL RATING is in the NORMAL range. QSA indicates the sample contains LOW levels of the specific contaminants
known to produce / promote varnish deposits. Although testing indicates current lubricant conditions are satisfactory, periodic QSA testing is
recommended as fluid conditions can change dramatically over time. Recommended sampling interval for this component is quarterly. Please
refer to the routine report for additional data and recommendations."
Varnish Potential rating 7 (out of 100), and filterable contaminants less than 1mg/L
