A couple of days ago transmission on the 95 Galant (140,000 miles) started slipping out of overdrive. Seems like it's doing it after sitting for an extended period of time (like overnight). Afterwards it works fine. I have a 30 mile commute. First thing in the morning the transmission would not shift into overdrive (however, if I pull on the shift lever, it'll shift, but then slip right out. This happened before, but on only on a couple of occasions. And at that time, it would shift right back in and there wouldn't be any problems). Made it to my destination. Later in the day had to drive around town for a little bit (everything seemed fine then). On the way home the transmission performed pretty much flawlessly.
Decided to change the fluid and filter in it today. The fluid was dark red, and the filter had all sorts of clutch material on it (no heavy shiny filings though, just thin powdery stuff). Last fluid/filter change was less than 10,000 miles ago (8 - 9 months of highway driving, and I usually try to take it easy on the car). The transmission seems to be working fine now, but the real test will be tomorrow morning.
Anyway, the question is this: should I try any of those "slippage stoppers" type of things (Lucas has one, Trans-X, etc), or Auto-Rx? Or should I just save my money?
Also, there are no magnets on the bottom of the trans. pan in this vehicle
(probably the reason why all the crud gets on the filter). Would it be wise to install one, or would it interfere with anything? If installation is a good idea, where would be a good place to get an item like that?
