Originally Posted By: 901Memphis
ATP 205 is the best chance you have. If that doesn't fix it your going to be in for a new rack which is probably an $800 job
+3 ^^ I will be the third guy here to swear by ATP 205. I've used it on 3 vehicles with satisfactory results. As I recollect, the label on ATP 205 wants you to use it by about a 1/3 mixture in a PS setup. Use a turkey baster to suck enough fluid out to make room for the 205, and after installing, give it a few days to work. I think I actually ended up with about 1/2 full of ATP; but it worked. Yes, it is meant for rubber seals, and no, I doubt you have Teflon PS seals unless you drive a Delorean.
Edit: eBay http://www.ebay.com/itm/ATP-AT-205-Re-Seal-Stops-Leaks-8-Ounce-Bottle-New-Free-Shipping-/361284259916?hash=item541e38504c:g:TicAAOSwrklVOECS
