slick 50 one lube
Anyone use or have any opinions of Slick 50 One Lube penetrating oil? Its on clearance at a local parts store cheaper than WD-40 and was thinking of picking some up.
thanks
whats so bad about it? is it the unnecessary Teflon? or just the fact that its a Slick 50 product?
I bought a case of 12 for 18 cents each at Checkers on closeout. I use it every week around the house with no regret nor problem.
It's OK not great and I would not seek out buying it but if you can it cheap it is oily and will work as well as wd40 on most things. I hate the spray button at least mine sucks when using it you may have better luck.
