2001 Chevy Blazer Trailblazer 58000
Tried to siphon out the atf today so I could drop the pan and install a drain plug. All I could get out was one quart! I think the problem was I could not get the plastic hose down to the bottom of the pan. Does the dipstick tube get narrow down at the end??
I am going to try and hook up a smaller plastic hose to the fluid pump and try again. Understand there is about 5 or 6 quarts in the pan and don't want to try and drop it with all that fluid in there..........
Will change the filter when I finally drop pan and will exchange fluid several times so higher percentage of fluid is new.
