Simple Green Pro HD vs ?????
Texas
Is there any cleaner/degreaser that’s better or equal to SG Pro HD (kind to aluminum and more eco friendly)? Looking for my go to in my new ultrasonic cleaner, primarily for corrosion/rust. Started using this thing today on bunch of old tools at the bay home that were rusted up and it’s very impressive. At $15 a jug wondering if there’s anything else I could be using and SG non pro hd wrecks aluminum.
Reg Simple green is better for rust and carbon on steel, let it soak overnight before tanking it.
But it's not good for aluminum. I want something universal so I can toss car parts, boat parts, anything in there.
Then just use the Pro HD, there is no jack of all trades with these cleaners, I use 3 tanks with different cleaners. You can soak steel parts in a seperate container with regular SG, rinse with water then put it in the tank with Pro HD.
found this stuff called Zep industrial cleaner, works well and can be easily diluted to your special needs and is somewhat safe.
I have used the zep (safe for aluminum) and the simple green pro hd in my ultrasonic for everything including aluminum.
LSx rocker stand bars came out like new as did rocker arm bodies. My go to before I press in new trunnions.
