Hello
The combo valve on the Champ filter works in a pretty cool way. The rubber adbv has a small lip that covers the smaller holes on the inner ring of the tapping plate. The durometer of the rubber is such that when the pressure differential is at the relief valve opening rate it will uncover the small holes to allow oil flow. It actually works very well in testing and does not leak unlike a well known competitors attempt at the same design. That said, the LS engines all have block mounted bypass valves anyway. The reason these filters have bypass valves in them is because the AC Delco and Ecore product lines are consolidated lines meaning these part numbers fit other applications that require a filter mounted bypass valve.
Nice write up BTW.
Nice write up BTW.
