This shower door touches the fixed portion glass on the top but not the bottom. Its a frameless door held by 2 hinges one of which is pictured. I assume there is a gasket/cushion between the metal of the hinge and the glass door that needs replacing. I am thinking when the screws are loosened I can adjust the door a little.
Also need replacement of the original door seals to make it waterproof.
Can anyone ID the make/model?
