JHZR2
Staff member
My house is from the early 1930s. I have a 36 x 84" 9-lite prairie style front door.
SOmething like this, only the glass extends lower down.
The door has some faults, but to replace it will easily cost me $7000. Id liek to try to get a few more years out of it if I can.
The biggest issue is that the door is saggy. It sags likely because it is a big, heavy door and the hinges are worn. Looking at the door jamb (no guarantee it is square), the door hangs quite a bit, so there is a big gap on one side. I assume that new hinges would fix that, right?
Besides the hinges, the construction of the door is off by a bit. Granted on a 9-lite door, there isnt a lot of wood to provide structure, but the solid wood in the bottom 1/8-1/4 of the door has started to hang crooked too, which actuall has created a gap in the pieces of wood that make the door (very small, but the draft is felt in the winter).
I am planning to refurbish the door as best as I can over the next month or so. I will be going with some new hinges, refinish the wood, and try to tighten it up. So, a few questions:
-If one of the wood screws that hold the hinges in place doesnt really bite anymore, should I go longer and thicker? How do I best sure up the hole so I can screw in and it will be tight and long-lasting?
-If I take the door down, and try to square it up a bit, can I drill a long hole thought he solid wood parts, and insert a dowel with glue on it to create a "spine" of sorts to make it more rigid?
Any help would be appreciated.
Thanks!
Thanks!
