After reading Oil 101 posted by Bob, I now realize that I might have been believing certain myhts as being "true". I've been very confused, even obsessed about certifications and grades in my choice of oils - right up unitil now. If I learned right, all that really matters is the 40C Viscosity & the 100C Viscosity. That's where the answer lies. Therefore I've compiled this small bit of info, and if you follow my thoughts, perhaps one of you folks can agree (or) disagree with my logic.
Mobil 1 Advanced Fuel Economy 0W30, 40C=56.7, 100C=10.6, VI=180, HTHS=3.06
Mobil 1 EF 0W40, 40C=75.0, 100C=13.5, VI=185, HTHS=3.80
Castrol GC 0W30, 40C=72.0, 100C=12.2, VI=167, HTHS=2.90
Tot Qrtz E 0W30, 40c=68.4, 100c=12.2, VI=170, HTHS=>3.5
Pennzoil Ultra 5W30, 40c=57.5, 100c=10.3, VI=169, HTHS=3.10
Castrol EDGE 5W30, 40C=54.1, 100c=9.80, VI=???, HTHS=????
1) Since the "Ideal" viscosity for an engine at temp is a 10.0, and the LOWER the viscosity at 40C, means a less "thick" oil, strictly based on these facts, Mobil 1 Advanced Fuel Economy 0W30 or Pennzoil Ultra 5W30 will provide practically identical cold startup performance, and protection at running temp. Edge 5W30, will "flow" a bit more cold, but might not "protect" as well at running temps.
2) Why don't they simply label oils based on their Cold/Hot performance? For example, instead of Mobil 1 Advanced Fuel Economy 0W30, Why not Mobil 1 Advanced Fuel Economy 57/11 (57 being the COLD perf, and 11 the HOT (rounded))?
3) From what I see, the "perfect" COLD start properties/HOT protection choices will be the Mobil 1 Advanced Fuel Economy 0W30 and ironically the Pennzoil Ultra 5W30 with a very close third going to Castrol Edge 5W30. It is very strange to me that the 0W30 specs are almost identical to the 5W30 specs in these cases. Of course, again that is in keeping with the "ideal" 10 at running temperature.
So I ask... where does the VI 167>185 come in? Which is better? It seems from some of the answers I have had that the higher the better, yet Mobil 1 0W40 has an astronomical 75 Cold start fluidity and is still a "0" weight, at least supposedly.
As far as HTHS goes, the higher the better it seems, but since I religiously change my oils every 5000 miles (8000 KMS), evidently, oils shreading, thinning, falling apart, is NOT an issue. I sure hope I got that right.
Therefore, based on Oil 101, The ideal oil would be the Mobil 1 Advanced Fuel Economy 0W30, with a relatively high VI, Low cold number, a higher 10.6 hot number for all the vehicles.
Now, I can't help myself but to return to the magic question, or puzzle. The oils that meet the BMW-LL and B 229.5 all have a 12-13 hot and a much higher 68-75 cold number. I went from a 75 cold to a 68 cold, and there was a DRAMATIC difference (the BMW)- just imagine a 54? but the low cold number oils do not meet the LL/229.5 yet they advertise 15,000 miles between oil changes just as the LL oils do.
Maybe I am missing something somewhere with the VI?
Am I getting this, or am I heading totally in the wrong direction?
I truly appreciate all the insight/replies I have had from a lot of you folks. I spent a lot of money on my cars, and I really hope to keep them a long time. The BMW and the Benz are NOT on Warranty, the Jags are, Both till 2014, BUT, the Supercharged will probably mileage out in the next year and a half or so. The X only has 40K miles on it.
Once agin, Thank you.
