I would say that a turkey baster exchange in the master cylinder, and ONLY doing that, may cause more harm than good. As pointed out, moisture is the enemy of any brake system, and the small benefit you might get via clean fluid diffusion through the system is probably outweighed by the potential of introducing moisture and/or contamination into the system by the frequent opening and closing of the master cylinder.
I would advise to do a complete fluid exchange by:
1) Turkey-basting the old fluid in the master cylinder out with fresh fluid, so you have a volume of fresh fluid to start with.
2) Bleeding each line through the bleed screw at the caliper. Bleed each line until the fluid is decidedly clear. Keep the master cylinder full as you proceed, so you don't get air into the line.
3) Bleed each line in the order prescribed in the service manual or owner's manual for your vehicle. It's often RR-LR-RF-LF, but not always. For our cars, you actually start at the LF and work clockwise around to the LR.
