- Joined
- Apr 15, 2023
- Messages
- 212
Should I use certain spark plug grease when changing spark plugs? Or is it better to install without these spark plugs?
^^^This has worked well for me for 30+ years.On the threads use just a dab of anti seize. For the coil boots a little dielectric grease in the ends.
This ^^^^^^^^^On the threads use just a dab of anti seize. For the coil boots a little dielectric grease in the ends.
Use dielectric grease which is a silicone grease on the boots and I would not use antiseize on the threads. Anti seize has caused problems with plug blow out on some Ford 4.6, 2V engines.Should I use certain spark plug grease when changing spark plugs? Or is it better to install without these spark plugs?
There is no consensus on BITOG on this issue. Lots of anecdotal evidence. IMO it doesn't really matter much. Do whatever lets you sleep at night.Should I use certain spark plug grease when changing spark plugs? Or is it better to install without these spark plugs?
But in those years you probably never ran spark plugs in an aluminum head for 100,000 miles as is absolutely routine with Iridium plugsI'm almost 60 and started changing plugs at about 13 or so. In the hundreds I've changed I've never used anything on the threads or boots.
Bingo! This is what a lot of people don't realize. Years ago cylinder heads were all cast iron, and you were lucky if you got 12,000 miles out of a set of plugs.But in those years you probably never ran spark plugs in an aluminum head for 100,000 miles as is absolutely routine with Iridium plugs
