Should I extend my oil changes
VT
with using Castrol Edge W/Titanium 5w30 and K&N oil filter. I've been doing it at 3,000 mile intervals before I changed to this filter and oil configuration which I am nearing the 2000 mile mark and it is still able to see through very well.
Yes. At least 7500 miles is reasonable in that year GM car running on synthetic oil. Does your car have an Oil Life Monitor?
Color or clarity doesn't really tell you much about the oil's condition. If you want to know whether you can run longer between oil changes, it's best to do oil analysis.
No it doesn't I am glad it doesn't because it would drive me nuts.
I will when my next paycheck comes in because I still have a sample container to send in just haven't had the time to do it yet.
I know most of my miles are all 12 mile one way trips to work and back. Most of it is all 50mph and 40 mph except about 3 miles which is 25mph through a small city.
I don't know a thing about Castrol oils but I do 10K OCIs with ease using Mobil 1 oils. Frankly, you are wasting oil doing what you do.
Do the UOA - in Vermont winters, particularly with short trips, you'll get a fair amount of condensation, and the OCI may need to be shorted (which, with a synthetic, I would say is closer to 5 or 6K instead of say, 8 or 10K) as a result, but the only way to know in your application is with the UOA.
I've found that a 7500 mile interval is very, very conservative when using a good quality oil (as you have been) and driving my car in mostly city use. Granted, I am now in a mild climate, not Vermont.
Look, the UOA is cheaper than a single oil change - if it allows you to safely extend your interval, and cut your oil change expense in half, then it's money well-spent.
If these trips get your oil to operating temp for a couple minutes or more, you could easily double what you do now.
I know during the winter I usually get some yellow moisture on the inside of the cap but none during the summer.
While a used oil analysis is useful if you want to do extended intervals, you could significantly increase your interval without it being an "extended interval". I honestly wouldn't bother with a used oil analysis unless you want to do more than 5K in the winter and 7.5K in the summer. Even those intervals would be very conservative.
I also think pulling a sample @ 3K will be a total waste of money. The oil just won't be far enough into its service life to tell you anything. I'd wait to 5-6K at a minimum before doing a used oil analysis.
That sounds like what I am gonna do this time around and wait to do a used oil analysis until the end of this summer. or so.
