The truck is an 07 F150 with the factory tow package which includes a decent sized transmission cooler. I have a Gryphon programmer that shows several things including trans temp. Been watching it as the ambient temperatures drop, and with outside temps at 40 degrees F it takes over 30 miles at 70 mph to get the fluid to 145-150 degrees. During the summer I run 150 to 160 degrees normally. Should I block the cooler to get to normal operating temp or is cooler always better with the transmission?
And since we are BITOG, the current trans fill is Motorcraft Merc V with Lubegard Red and a Magnefine filter added. I serviced the trans 10K miles ago and it did use to run a few degrees hotter before the new fluid and Lubegard.
