2005 Toyota Rav4
My wife came home from work with a problem, 12 miles she drove from work, no a.c., with an engine code light on.
So I drove 3 miles to AutoZone to get the code read, temperature coolant sensor, bought one. I had a.c. to there and back. The temperature gauge was midway, fine. Went home to install the temperature coolant sensor, opened the hood, heard boiling noise from the radiator overflow container, it was empty. I opened the radiator cap, carefully. The cap without the parts came off, the spring and rubber seal were left in the radiator neck. Of course it wasn't opening. Took the parts all out. Mixed 2 liters of old new green Prestone with silicates, only thing I had on the shelf, it took all of it. I feel when I get this problem solved I would flush the Prestone coolant out and refill with Toyota red. Maybe I should have added just water? So back to AutoZone to buy a radiator cap. Zoom ahead 2 weeks, I did not replace the temperature coolant sensor, the radiator level is fine, no boiling, temperature gauge seems to be working fine, a.c. is working. Should I replace the temperature coolant sensor? Does it become inaccurate with overheating? Did the engine overheat enough to cause inaccuracy?
