I posted about this vehicle previously, a '01 Camry with the 5S-FE 2.2L and just over 38,150 miles as it stands now. Engine oil is Mobil 1 0W-40, if it matters, with a OE Denso filter (Thai version).
The initial problem was that the coolant temperature remains just a wee bit above the cold mark on the gauge, and never reaches the half mark. The only time you see the temperature rise is when the engine is left to idle. Only then does it reach a bit under the half mark. The thermostat was replaced with an OE Toyota unit, as was the coolant temperature sensor (OE as well). The problem did not go away.
I used an infrared temperature gun pointed at the top of the radiator, and it read 60 C/140 F, which is low compared to the 82 C/180 F the thermostat is set to. This was when the temperature gauge rose up a bit.
Driving it tonight on an open highway, I hit 100 MPH and immediately noticed the coolant temperature gauge was under the cold mark - i.e. where it points to when you start the engine first thing in the morning. I dropped down to 75 MPH and the temperature went back up to the cold mark. Ambient temperature was 13 C/56 F.
The only other thing that springs to mind is a sensor located by the cooling fans on the radiator (on the bottom left (passenger) side). Any 5S-FE gurus know what else could be considered an offending part? I'm having a hard time tackling this one. Thanks!
