Trade it for ammo ...Alberta and BC pulp mills are working at normal capacity...there is no shortage but I'll sell you a roll if you need it.
I feel like silent running furnaces are under rated. My old house had an older 80% and there was no mistaking when it kicked on... the York 95% in our new house is incredibly quiet, but does not have a 2 stage burner or variable fan speed. Did they replace your AC unit as well?I got a Rheem 97% efficient furnace installed at the beginning of this year I believe late January early February, got a fantastic price on it installed. One of their top of the line models. The installer also had a coupon for a free Aprilaire whole house humidifier if you bought the furnace. Nobody could believe the deal. I guess timing is everything. It is weird there is a furnace shortage. That means you are not going to get good deals either.
By the way I can recommend Rheem to anyone, it is two stage burner, completely silent, and the house comfort is like night and day compared to the old furnace I had. I actually turn down the thermostat because the heat is so even. It’s a two stage burner and continuously variable speed fan not fixed speeds.
While those features cost a little more, usually on the rebates for heating systems, those features will net you a higher rebate so they might pay for themselves. I wonder how many people actually do a manual J calculation when replacing a heating system. Those 80% systems replaced by a 97% could be replaced by a smaller system as a 105k btu system at 80% could be an 85k system at 97%.I feel like silent running furnaces are under rated. My old house had an older 80% and there was no mistaking when it kicked on... the York 95% in our new house is incredibly quiet, but does not have a 2 stage burner or variable fan speed. Did they replace your AC unit as well?
As for shortages... I noticed at work they are using a few more suppliers for raw stock than normal.
Unfortunately, heat and electronics do not go well together. Often your energy savings already accrued get offset by the high replacement costs of those components in a high efficiency furnace.Last summer one of my brothers took a financial hit when a board on his expensive high efficiency heat-pump fried and no replacement was available. The system was not very old and he had to get a whole new system. Ouch.
Ammo will be the new currencyTrade it for ammo ...![]()
I’m not sure hoarding is that big of an issue. People are using the bathroom at home way more than before. People aren’t going out as often shopping, and they’re working from home. Have to buy TP for home use. Commercial TP is totally different.The TP shortage is not supply driven. Hoarding is the issue. The only reason there is even a run on TP is because Australia actually gets a lot of theirs from China who stopped shipping it. The media whipped it into a worldwide issue instead of a very localized problem. Alberta and BC pulp mills are working at normal capacity...there is no shortage but I'll sell you a roll if you need it.
Are you telling me I will not be able to get breakers if I luck out and get an electrical panel?meadow,I know what you are saying about electrical panels, I work for Square D and we are working 7 days a week making electrical panel and cannot keep up with demand. Small breakers that are used in these panels are even worse.
Yes and certain repeat posters display it more than others.Pretty big shortage on common sense, ability to discern truth and think for yourself.
Discern is a powerful .Pretty big shortage on common sense, ability to discern truth and think for yourself.
