Never new how they were shipped by railt
https://www.railwayage.com/mechanic...k-in-time-the-gm-southern-pacific-vert-a-pac/
Come on, they were 1/2 decent cars. Just a scaled down GM A-body style car on aSurprised the engines didn't fall out in that position.
"The Vega was delivered topped with fluids, ready to drive to dealerships, so the engine was baffled to prevent oil entering the number one cylinder; the battery filler caps high on the rear edge of the casing prevented acid spills; a tube drained fuel from carburetor to vapor canister; and the windshield washer bottle stood at 45 degrees"What happens to the oil in the pan or the gas in the tank?
Didn't we have this thread a year go?![]()
The problem was not with the aluminum engine, GM had perfected the honing and etching of the block bores before the first car had been sold. The problem was simple overheating due to an improperly designed cooling system. GM rectified that later but by then the damage to the brand was already done.A friend had a Vega. (Not Vegas). Horrible car. The engine blew early on. He got a new motor and the forklift driver dropped the crate and cracked that block too. He got rid of it.
Aluminium engines were forward thinking but not yet perfected.
Same process and material as used on the Porsche 928 V8. I did hear the issue was with valve seals in the C.I. head more than block wear, but I never verified this. I didnt tear down the engine.A friend had a Vega. (Not Vegas). Horrible car. The engine blew early on. He got a new motor and the forklift driver dropped the crate and cracked that block too. He got rid of it.
I thought they were some of the better looking things from GM and had always wanted one, but by that time they had all but disappeared from the used market probably because of the mechanical issues. Did have some Chevettes instead which weren't half bad either.Come on, they were 1/2 decent cars. Just a scaled down GM A-body style car on a
Unit body. A great fun, tossable car with the Polyglass Bias- ply tires.
We lost all the fun tail-out attitude with the advent of radials with their tricky
stick, stick, stick then Whoa! - CRASH! handling characteristics.
This is of course before the Bridgestone- Lee Trevino, "You can feel it when you drive" Super filler technology of the 80's.
The came the "safety understeer" era in the 90's. A Fun Handling Deathnell to most cars.
