Huhwhye
Will that be any different and why?
Quote:
Maybe you were draining sheared (and warm?) ATF and replacing with ambient, fresh RP?
Quote:
Earlier undummy quoted "Synchromesh" as being ~9 cst. From the context I think he meant "Synchromax". He was stating that RP is thicker than ATF. It is not. The datasheet indicates Synchromax is 7.7 cSt.
I ran RP SM for one round in my ZF 5-speed (1998 BMW). I wasn't impressed or disappointed, but it sure was thin. I've run MTF-LT-1 (factory), Redline D4ATF, RP SM, Redline MTL. I chose the MTL most recently to step up a grade from ATFs.
Redline's datasheets (like http://www.redlineoil.com/pdf/6.pdf) indicate that D4ATF is 7.5, and MTL is 10.6.
When I first put MTL in, I noticed no downside and an improvement in shifting in certain circumstances. In weather below freezing I noticed slightly more difficultly shifting until the fluid warmed a little but it was barely noticeable. Now I've noticed shift quality going downhill, but I'm not sure if I might be looking at shifter linkage play coming into the mix instead of just the fluid.
I do know that only with RL MTL did a cold-weather sticky 5th gear detent go away completely so that it is unnoticeable. This issue was documented in a Roundel magazine several years ago but I've lost a working reference to it. In sub-freezing weather if you press over to 5th one of the springs doesn't pop right back to center the stick in neutral unless you push over to the 1/2 gaiter. With MTL this never happened once this past winter.
Quote:
Well, I'm curious where this goes, just bought a B2300 5sp and the shifting is horrible
