Shell Helix Ultra 5w40 on 2000 Camry 2.2L
Singapore
Dyson Analysis
Customer Name : Ken Wong
Oil Brand/Weight : Shell Helix Ultra 5w-40 syn
Type Equipment : 2000 Camry 2.2L 4
Miles/Hours on oil : 4997km / 5 months
Total Miles/Hours : 62015km
Results ppm/%
Wear
Copper 7
Iron 7
Chromium 1
Lead 0
Aluminum 2
Silicon 8
Tin 1
Additives
Molybdenum 0
Sodium 6
Magnesium 843
Zinc 810
Potassium 2
Phosphorus 684
Calcium 1040
Physical Properties
Water negative
Fuel negative scale negative,trace,positive
Antifreeze negative
Soot/solids 87
Oxidation 0 scale 0-199
Nitration 10 scale 0-199
Sulfur 8
TBN 8
Vis@100 C (cSt) 13.8 SAE 40w
TAN na
Terry's comments are not shown as he has requested that his comments remain confidential. Sorry guys.
Previous Analyses:
http://theoildrop.server101.com/cgi/ultimatebb.cgi?ubb=get_topic;f=3;t=000338
http://theoildrop.server101.com/ubb/ultimatebb.php?ubb=get_topic;f=3;t=000168
Comments welcome.
Other than the soot it seems like a god report. What is up thith the soot? Its out of control. How much is the stuff??
The soot levels have increased 10 times! Wear levels are double.
The shell helix ultra costs S$84 per 4 litres here. (US$48)
What part of "Ultra" am I missing. Ultra low on Moly or Ultra low on ZDDP. I think I'd rather put Pennzoil Dino in my Lamboghini!!
Q
quote:
Originally posted by Ken4:
Dyson Analysis
Results ppm/%
Wear
Copper 7
Iron 7
Chromium 1
Lead 0
Aluminum 2
Silicon 8
Tin 1
Additives
Molybdenum 0
Sodium 6
Magnesium 843
Zinc 810
Potassium 2
Phosphorus 684
Calcium 1040
Physical Properties
Water negative
Antifreeze negative
Soot/solids 87
Sulfur 8
TBN 8
TAN na
Previous Analyses:
Comments welcome.
quote:
The additive levels are very similar to the older 15w50 SJ previously used. But notice the oxidation and nitration levels are at 0% & 5%, and the TBN still high. Almost like brand new condition.
quote:
Originally posted by YZF150:
The 10x soot suggests analysis error.
I doubt it's sampling error either bcos I used the same method as for the previous analyses. i.e. collect sample midstream during oil drain.
Thats such a interesting oil , the blend of bases used ect .
It would be very interesting to see this oil ran in a couple other engines using USA gasoline .
It's available in the USA in 55 gallon drums . Works out to a little over 4 bucks a quart
I doubt we will ever get to use an OTC oil similar to this base oil but the new EOP from Shell we might !
