Just received my lab report on the last oci.
Shell Helix Ultra 0w-40, 10782km (6735mi) in a Saab 900 turbo 16V (B202L).
https://turboseize.wordpress.com/2016/08...-turbo-b202l-2/
Saab 900 turbo 16, model year 1985. Engine code B202L. Total mileage 591006km, which equals 369148 miles. Engine rebuild at 410000km/254700mi due to defective LH-jet (did not enrich enough under full boost and killed a piston ring).
OIL Shell Helix Ultra 0w-40
MILES IN USE 6735 (10552km), 5 months
MILES 369148 (591006km)
SAMPLE TAKEN 16/08/19
wear metals (mg/kg)
IRON 13
CHROME 0
TIN 0
ALUMINUM 1
NICKEL 0
COPPER 8
LEAD 1
MANGANESE 0
pollution (mg/kg)
SILICON 4
POTASSIUM 1
SODIUM 4
WATER (%) IR-GLYKOL negative
FUEL (%) 0.84
Additives (mg/kg)
CALCIUM 2182
MAGNESIUM 12
BORON 50
ZINC 973
PHOSPHORUS 742
BARIUM 0
MOLYBDENUM 48
SULPHUR 1774
state of oil:
visc. @40°C (mm2/s) 70.02
visc. @100°C (mm2/s) 12.77
VI 185
OXYDATION (A/cm) 4
NITRATION (A/cm) 3
SULFATION (A/cm) 6
dispergency* (%) 85
SOOT INDEX** BN 9.71
* the german word was "Schmutztragevermögen", hope I translated that right.
** the lab has introduced the "Rußindex", an in-house tool to check for soot in
gasoline oil, as soot from direct-injection engines will not show correctly in the
standard test for diesel oils
Here is the original. On the left: Shell Helix Ultra, then Aral Super Tronic, to the right Mobil 1 "New Life".
Blog (in german):
Prvious uoa discussend on bitog: http://www.bobistheoilguy.com/forums/ubb...105#Post4045534
wear metals (mg/kg)
IRON 13
CHROME 0
TIN 0
ALUMINUM 1
NICKEL 0
COPPER 8
LEAD 1
MANGANESE 0
pollution (mg/kg)
SILICON 4
POTASSIUM 1
SODIUM 4
FUEL (%) 0.84
Additives (mg/kg)
CALCIUM 2182
MAGNESIUM 12
BORON 50
ZINC 973
PHOSPHORUS 742
BARIUM 0
MOLYBDENUM 48
SULPHUR 1774
state of oil:
VI 185
OXYDATION (A/cm) 4
NITRATION (A/cm) 3
SULFATION (A/cm) 6
dispergency* (%) 85
Blog (in german):
