SFR 100 Petroleum Oil Fortifier
What specifically have you diagnosed and fixed? How was the "fix" done? How was the diagnosis.made? Do you have testing equipment that you use to validate your observations?
Engine oil does not have “crappy lubrication properties”. That’s a load of complete nonsense, and if you think this additive is just the ticket to correct that, well then you’re farther away from the truth than I thought.
And here we go, the uninformed narrative that “synthetics as mentioned are actually mainly in-synthetic”. That shows you are also misinformed here as well.
So are you marketing this additive? If you are then you need to learn a lot more before you drag it in here thinking we might be impressed with your non-answer as to what it does. I mean in a technical sense. We know what the one (and only) constituent of the product is besides a mineral oil carrier, what does that specific additive do exactly?
Sorry but not all engine oils are the same. No marketing here. You do not know what you are talking about.
Please, read again.
It's not up to you to tell me that engine oils do not have crappy lubrication properties. It's like telling me there is no bad gas. Keep trying.
So what exactly does that one active compound do in this additive again? I have a minor in Chemistry so you can be a little technical.
I would like to but you are here to burn down any oil additive idea because it's a no go in your "chemistry" book no matter what. I came here because of my first post only. I am done. Have a nice day.
  • Haha
Reactions: 4wd
Heavens, feel free to elaborate. I’m open to hearing.
If I need the stuff, I need the stuff. Right?
Since this thread contains only claims and no validation about this additive, and since the OP says he's "done," this thread is closed.
  • Like
Reactions: GW.
