Just replaced the supercharger coupler, the serpentine and supercharger belts and four pulleys. The battery was removed and the alternator dismounted for easier access.
The operation went well. Upon testing, I have a service engine soon light and when plugging into the data port, I have a connection error. I have taken it to Advance Auto and their scanner can not make a connection either. The vehicle runs great. Heads up display works along with the instrument display center. No abnormal readings. Cigarette lighter circuit is working. There are no blown fuses in the UHJB or in the fuse panel in the passenger side foot well. No fuses blown in the panel under the rear seat. All ground points near the battery are solid.
Tough one to figure. Anyone experienced this or having suggestions to repair? I do not know the actual circuit the data port gets its power from. I have the owner's manual and fuse panel covers with fuse assignments but none defining power for the data port.
Vehicle - 1999 Buick Ultra 118k
