This was off a friends 2018 Ford Escape, with just under 20,000kms on the vehicle (1.5L Ecoboost), she said she had her first oil change at the Jiffy Lube down the road
OLM was at 20% and she thinks it was about 10,000kms ago.
First off I mangled this filter, won't be winning any beauty contests. It is just slightly too big for my exhaust cutter, but I still tried to use it, then dremeled some of it, then once I was fed up with the whole situation some brute force.
Not sure who makes these filters but one thing that struck me as odd, is when I first took the filter off I couldn't see the ADBV, there is a second set of inlet holes below the ones at the top, then the ABDV was under that. Also the plastic cage on the inside was new to me.
I imagine these are the cheapest of the cheap jobbers at Jiffy.
I put in some Pennzoil Platinum 0w20 and a XG 3614.
