Originally Posted By: Lethal1ty17
……. I just got the alignment rechecked at another place and everything is still spot on within spec. …..
Allow me to comment on this.
Either the alignment was spot on or it is within spec (or out of spec), but it can not be both. The print out you posted says it is within spec, but not spot on - and that's the problem.
Given the amount of miles you put on, the alignment has to be near perfect to get even tire wear - and that's exactly what is not happening.
First, did you notice your steering wheel was not pointed straight ahead before they adjusted it? That's what that alignment print out says.
Second, the out of spec caster causes excessive camber every time you turn - which is where most tire wear takes place.
Yes, it is not uncommon for vehicle manufacturers to not provide adjustment for camber/caster - and that you have to either have a die grinder to free the top bearing so it can be moved, or have an offset bolt installed to get the suspension properly set.
Then there is the problem of not being able to rotate tires. My experience is that at 20K, alignments at the edges of the spec will start to see some irregular wear develop. You've got many more miles than that. Plus, the degree of irregular wear doesn't develop in a straight line. It is exponential! That is, it will be more than twice as bad at twice the distance.
And it doesn't matter if you fix the alignment, the tire wear that is already there will continue to get worse - because whatever the new pattern is, is put on top of the old pattern.
