Originally Posted By: Colt45ws
*shrugs* Ive always heard it called a bung. First time Ive heard of a 'thread-o-let'.
But, then, you've been in pipe fittings longer than Ive been alive.
Colt, it's all good. I am thinking that "they" call it a "bung" because it plugs a hole.
You can order that thread-o-let from Summit and find a welding shop to Tig weld it onto your pan. Usually shops have a minimum fee of $25. It took me less than 5 minutes to weld mine. I used to run a pipe fab shop so I had EVERYTHING available to me.
If you do go that route go to Home Depot or any hardware store and buy a brass plug for the drain. And, "NO" Teflon tape or pipe dope is needed!
Yeah. Ive been thinking about doing the same with a OE 8.8 alum cover I have. Obviously buy a aluminum thread o let. I have a spare one I got off of somebody that I ended up putting on the CVPI because the one it had I didnt want to mess with cleaning up. I think the person that opened it last took one of those tubes of RTV meant for use in a caulk gun, and used the whole thing. Its a mess and thats really the part Im not looking forward to.
Anyway, Ill see if I can find somebody to do some welding on the side. I know plenty of welders at work, its finding somebody who has equipment at home to do it. I'd like to get it setup so I can put it on when I drop the pan and do the JMod to the trans.
Colt, when I do ANY differential service, where I have to remove a cover, I always go back with a gasket.
This is what I use on the 8.8.
http://www.oreillyauto.com/site/c/detail...4&ppt=C0363
