- Joined
- Jun 17, 2024
- Messages
- 4
Hi Folks!
First time poster, long time fan...
I had a shop change an oil cooler on a Mercedes Sprinter 2500 (3.0L V6 Diesel). This is a very involved job - like 17 hours of tear down, and apparently requires neurosurgeon cleanliness, and meticulous attention to detail. One important bit is not only does the coolant need to be drained, but also then vacuumed to make sure no residual coolant remains in the system when the oil cooler is removed. This is a critical detail that is not common on any other automotive engine I'm aware of.
Also, the oil cooler sits in the valley of the engine, and the oil ports apparently drop straight onto the #4 and #5 main bearings. No filter in between.
I picked up the van a couple weeks later, and made it about 50 miles before the engine seized. I had it towed to the Mercedes dealer, and apparently this is a common problem if you're not familiar with the specifics of this job. One of two things happened -- either dirt fell into the oil ports and killed my main bearings (which should be obvious via teardown and inspection of bearings #4 and #5.... or... coolant got into the oil ports and did the same thing.
Interestingly, this engine requires a specific Mercedes oil grade - 229.52. Only a few manufacturers/products and oil weights are approved for use on this engine. In 2013, there were only 5 oils approved. Now the list is 30+. My point is, the shop put in 15w40 oil. Nowhere in the approved oils list is a 15w40 oil. (It is 0W-30, 0W-40, 5w30, 5W-40 ONLY)
My plan is to sample the oil and send it out to a few labs for analysis. I think the different/unapproved engine oil weight will be easy to prove at least negligence. How sensitive are used oil analysis to coolant? If they dropped a few mL's of coolant and it made it to the sump, would it be detectable? Any other suggestions on how to proceed?
Thanks all!
Thanks all!
