Search For Filters by Spec?
NorCal
I just visited the Wix Filter website and I really like how they have very detailed specs on each filter, but I was wondering if there was any place that a search could be done for a filter based on some of these specs. For example, if there was a particular filter I wanted with "X" thread, "Y" height/width", "Z" Micron Size Filtering...with search results showing a number of filters with those specs...
It would seem like it would be easy enough if there was access to search that information off the Wix (or any other) database.
Anyway, just curious to know...thanks.
Yes Use the pull down menu
You won't get to spec micron ratings, per se~. Also, make sure you use all versions of the thread that you want. In 3/4-16 there are 4 or 5, I think.
3/4-16
3/4x16
3/4 x 16
3/4 - 16
Something like that. The metrics are less duplicated.
Then when the results are shown you can reject the ones that have oddball gaskets and whatnot.
It's only a problem with the most popular thread in use on the planet
