Just be careful that transmission fluid doesn't run down across the sealing surfaces and interfere with the FPG making a good bond. It helps to let the old fluid drain as long as possible (overnight or more) if you can. Then a trick I use is to stuff a couple of paper towels up into the areas of the transmission where most of the oil still seems to be dripping (but not up so high or wrapped around anything such that you can't remove them later). The paper towels will help to wick out additional fluid, and you can go ahead and apply the FPG to the pan or transmission surface as directed. Just as you are ready to put the pan up against the transmission, carefully pull out the paper towels making sure you don't tear them or leave anything behind. The towels will help to make sure you have enough time to carefully place the pan in place. Once the mating surfaces have made contact you are good to go ahead and install the bolts.
