JHZR2
Staff member
Here is a question that maybe a long time user of FP, or a tester or knowledgable formulation expert might be able to answer:
I see a lot of people wanting to use seafoam, and based upon the smoking, it indicates that something significant is going on inside, likely cleaning...
Since FP is a cleaner as one of its functions, can anyone comment on real long-term use and testing that indicated that if an additive such as FP is used in correct doses consistently, even over hundreds of thousands of miles, that a heavy-dutycleaner like seafoam through a brake booster hose will NOT be needed? In other words, that the combustion chambners will remain SO clean from using the standard doses of FP that doing, say a seafoam regimen will ne of little to no use?
Thanks,
JMH
Thanks,
JMH
