Screw in Tire - No leak after removed - Patch or leave it?
Those seem to be misrepresented all too often though.
Opinions are like a certain part of mammalian anatomy: everybody has one, and most of them stink.
@CapriRacer is bringing facts. They may fly in the face of conventional wisdom, but that only because conventional wisdom isn’t based in facts.
You’re not going to find a standard or law governing a short screw in the outer row of tread blocks of an off-road tire, because it’s such an oddball situation that nobody would ever try to legislate around it. If you can find a tire shop that’s willing to take on that liability, then bully for you. Don’t be surprised if the shop tells you it needs to be replaced, though.
If the vehicle has TPMS, I'd leave it alone.
The only time I'd worry about it would be if the tire was on a high performance vehicle that saw high speeds and/or high concerning loads. If so and because of the location of the screw, I'd replace the tire, even if it held air.
Scott
I always buy the hazard warranty. I'm always getting the tires patched. America's Tire makes it easy.
By the way, possums are very sweet animals. They have teeth but they're totally non-aggressive. People mistake them for rats all the time.
By the way, possums are very sweet animals. People mistake them for rats all the time.
Since Discount Tire patch tires from free regardless, it only pays out if you need a whole new tire
The amount of times I needed a whole new tire I can count on one finger
Yeah I'm hoping the tire is beefy enough that it never went all the way, I'm just unsure how thick tires are!
I did think about getting my own patch kit and patching it if the tire shop won't, but I don't want to make it worse so to speak
You won't have to worry about a leak where the screw was.
You will have to be able to dismount the tire to patch it. I would get a plug kit instead.
Honestly I don't know if I could, the hole almost doesn't exist now I've pulled the screw
If you’re really concerned you could try one of the screw type tire plugs and cut it off without going all the way in, but I’d still be worried it could do more harm than good.
Thankfully I work from home, and also have an identical OEM wheel with identical tire as my spare
So if it does go flat, its not a big deal
SupremePossum
I think you answered your own question.
Do this:
Use your now Identical OEM Wheel and Tire that's currently your Spare as your New Wheel and Tire, and take the Current Wheel and Tire that you removed the Screw from and use it as your Spare tire.
Problem.Solved
Had exactly same on newly installed winter tires on the Merc. 3000 miles now since pulling the screw and all good, so assume it was a superficial wound. Car has an active TPMS so I can see tire pressures and temps throughout any journey as I drive. Nice feature but triggers my obsessive behavior as I watch the pressures change. Have got to where all tires stabilize fairly quickly at the target pressures. Very cool feature for those that have it.
