Originally Posted By: BRZED
You are not doing it right in your hypothetical scenario. You are not supposed to brake to the point where the wheels lock. You are supposed to brake until the freely spinning wheel slows down and power is diverted to the wheel that has traction. You don't want a fast spinning wheel anyway. You are at or near full throttle and adjust wheel speed with the brake. I've done it, so I know it works.
I have done this to climb away from a stop sign in the middle of about a 30% grade after an ice storm. I used maybe 1/4 to 1/3 throttle and just brushed the brake with my left foot as needed to reign in the spinning tire as it would get to spinning too fast. No need for anywhere near full throttle, just steady throttle that would normally be enough to do the job if you weren't spinning. The key is *lightly* brushing the brake pedal just enough to reign in the spinning tire without causing excessive braking to the non-driven tires.
