Originally Posted By: dishdude
Originally Posted By: BRZED
You are not doing it right in your hypothetical scenario. You are not supposed to brake to the point where the wheels lock. You are supposed to brake until the freely spinning wheel slows down and power is diverted to the wheel that has traction. You don't want a fast spinning wheel anyway. You are at or near full throttle and adjust wheel speed with the brake. I've done it, so I know it works.
Assuming it's a RWD vehicle, are you better off using your parking brake over the regular brake?
Yes, with a RWD you should use the handbrake, because you won't have to also overcome the braked front wheels by pushing. Although on ice it's not much of problem. Some FWD cars have handbrakes that work on the front wheels. That's also useful. And if your vehice is an old farm tractor you can use individual brake pedals.
