Schaeffer's oil
Originally Posted by zfasts03
I understand that Schaeffers 9000 Full Synthetic contains high levels of Moly. Are there any downsides to this level of moly, such as ring deposits or other issues? Is this moly tri-nuclear or something different?
Also some have commented higher lead using Schaeffer's 9000 oil. Is this for real or a rumor/myth? I was impressed with the million mile engine tear down, as far as low wear and cleanliness.
It's not high-moly, which means more than 600 ppm or so. I would call it mid-moly, as it's around 300 ppm according to PQIA. It's probably not trinuclear, as trinuclear moly is used in low-moly formulations (less than 100 ppm or so).
http://www.pqiamerica.com/March2013PCMO/schaeffersyn.htm
Moly is good stuff!
This is one of very few oils that actually lists the results of engine tests:
https://www.schaefferoil.com/documents/247-9003D-td.pdf
It's actually a very clean-running oil.
MHT-4 TEOST (ASTM 6335)
Deposit Weight, 10 mg (max 35 mg)
TEOST 33C ASTM D-6335)
Deposit Weight, 12.4 mg (max 30 mg)
Engine Rusting Ball and Rust Test (ASTM D-6557)
Average Gray Value 133 (min 100)
Sequence IIIG
130% Viscosity increase @ 40 °C (max 150%)
Average Cam & Lifter Wear, 9.8 μm (max 60 μm)
If there is indeed a pattern of high lead, it's not good though. TiredTrucker had really bad experience with high iron and high lead with the 5W-40 version of this oil.
https://bobistheoilguy.com/forums/ubbthreads.php/topics/1899200
