Schaeffers Moly EP Treatment
Pennsylvania
I am thinking about adding EP Moly to Chevron Delo 400 15w-40 oil. Will this be detrimental to the stock additve package? After seeing Bob's additive article, I am a little leary of adding anything. Does the moly settle out or get filtered out? Has anyone used it and had good or bad results??
Oilslick
to the board!
Do a search for #132 . I just got 107 replies to that search,more than enough information to keep you busy for a while!
Mark
quote:
Originally posted by Oilslick:
I am thinking about adding EP Moly to Chevron Delo 400 15w-40 oil. Will this be detrimental to the stock additive package? After seeing Bob's additive article, I am a little leery of adding anything. Does the moly settle out or get filtered out? Has anyone used it and had good or bad results??
The moly in #132 (and in Schaeffer's engine oils) is not visible, not in suspension, cannot settle out, cannot get filtered out. The moly is a chemical compound called molybdenum trialkyldithiophosphate. It is in solution, just like sugar is in solution in 7UP--you can't see it, it won't settle out, but it's there.
Molybdenum disulfide is the powered moly, used successfully in grease and gear oil, not suitable for engine oil, and not present in #132.
Ken
