Schaeffer's 293 75W-90 GL-5 Gear Lube
Hermon, ME
Sampled from a recently purchased, previously unopened 5 gal pail via suction pump.
Analysis by Polaris Labs.
Si-----27
Na-----1
K------2
Mo-----351
B------103
Mg-----10
Ca-----162
Ba-----2
P------1048
Z------66
All others 0
Water=
Visc. @100C= 16.1 cs
TAN= 2.71
A good TAN number.
It's too bad they didn't analyze the sulfur content. I would guess it would be about 3300 ppm or 3.3%.
Most diffy fluids contain a robust P-S package.
Yes, it would be interesting to see the sulfur content. I did notice this oil has a "lighter" smell than any previous EP gear oil I've had experience with.
I wanted to run this or the #167, but they only have it in pails. I have no use for 5 gallons of gear oil. I only have the rear diff in my car which takes..not even 3 quarts.
The #293 75w90 is available in quarts.
Originally Posted By: MolaKule
A good TAN number.
Wouldn't 3300ppm be .33%?
Just found this, thanks for posting.
Didn't realize until a few minutes ago how the specs for Mobil 1 75w-90, which Ive typically used in my MB cars, have gone downhill.
Looking at this, delvac 75w-90, and Amsoil SVG which I have had good experience with.
They may have reformulated it with the new Multi-Functional Phosphite additive.
What specs have gone downhill? Can you post the comparison?
A good TAN number.
It indeed would be and thanks for pointing out the decimal misplacement.
Sorry it took 9 nine years to see this.
