Valvoline Dino 75w-90 GL-5 20k mi Forester 5MT
NEUS
This was run between 2,500 and 22,400 miles in my Forester's 5-speed manual transmission. Viscosity was flagged. This was a Wix prepaid analysis kit. There was a bit of black sludge on the magnetic plug, but nothing that I haven't seen before. I didn't see anything shiny on the plug or in the oil. I'm concerned about the level of iron, and the viscosity is obviously low. Thoughts? I refilled it with the same, but maybe I should switch to something else.
Html:
Oil			Valvoline Conventional 75w-90 GL-5
Miles on Oil		19,900
Miles on Car		22,400
Sample Date		7/7/14
Aluminum		11
Chromium		2
Iron			119
Copper			6
Lead			0
Tin			0
Molybdenum		0
Nickel			0
Manganese		0
Silver			0
Titanium		0
Potassium		6
Boron			358
Silicon			24
Sodium			3
Calcium			84
Magnesium		0
Phosphorus		1808
Zinc			197
Barium			0
cSt Viscosity @ 100°C	10.9
Water %			<0.05
Solids %		<0.1
TAN			2.97
Bandito440
NEUS
Originally Posted By: Bottom_Feeder
As close as Valvoline looks to be what Subaru transaxles call for, my Impreza did not like it. Shifts into 1st and reverse from a stop were always crunchy. I finally spent some money on genuine Subaru Extra S and it cured the problem. http://www.amazon.com/Subaru-75W90-Extra-Transmission-Fluid/dp/B007L6Q1EK
How about that! Last time I looked, it was available only in 5-gallon buckets. I may go that route. Red Line 75w-90 NS is my other thought. Ah. I see now. That's rebottled by a dealer.
Central Washington
Wow, it sheared and dropped two grades to 80. In only 20k. From [email protected] according to the PDS its down to 10.9cSt. Just under an 85. 0/10 would not use. Would use the 80W90 instead or switch to synthetic 75W90 if you need low temperature performance.
Paradise of Florida
Trans is still young and breaking in. Shearing is excessive but usually normal in a manual. Try another gear oil. Idemitsu, Eneos, Redline, Motul, Torco... have nonLSD 75w90 gear oils.
dnewton3
Staff member
Indianapolis, IN
I would not worry about the Fe; this is break-in residual. You dumped the OEM fluid in 2.5k miles, and this is only the second load. Improvement should come on the next few OCIs. I'd say overall, the Valvoline didn't do a bad job at all, despite the Vis loss. The Fe is expected in such a young manual tranny unit, and will never be as "low" as engine UOAs.
Bandito440
NEUS
Thanks for the feedback. I'm amazed at how much the viscosity dropped. Pablo hooked me up with enough Amsoil Severe Gear 75w-110 for the transaxle and rear differential. I'll run that for 20k miles and get another analysis as long as the shifting remains reasonable and I still have the car.
