Guys (and the occasional girl),
I've been thinking about moly, piston slap and its effects on an engine's innards.
Bob likes to point out that a whopping does of moly does is not necessarily needed and that a little moly in an oil (200ppms or less) is plenty to allow plating throughout the engine. In general, I agree with this. We've seen some really good analysis of oils which have only 60-80ppms of moly in them. Doubling, tripling or quadrupling the moly content does not seem to halve, third or quarter the amount of wear. In fact, it may not reduce wear
at all.
BUT, what if your car has some sort of significant wear "issue" ... *cough, piston slap, cough, cough* ... and has a serious amount of its internal surfaces in contact and in need of moly plating? Would an oil with a mega-dose of moly be better in this case?
![[Confused]](images/icons/confused.gif)
An oil can show an improvement in its wear characteristics with just a very small amount of moly. Mobil 1 SS seems to be a really good example of this. But, if you need a great deal of plating (because many metal surfaces are in contact with each other) will a higher concentration be even better?
In short, I wonder if the concentration affects the
rate at which the moly plates up?
![[I dont know]](/forums/graemlins/dunno.gif)
It could just be, however, that a lesser concentration might just take a longer to plate a given area. So, if you are trying eliminate piston-slap noise, it might just take longer for a 200ppm moly oil to quiet the noise than an oil with 500ppm. But, how
much longer? A few hours of operation? Days or weeks? Even a month or more?
Of course, many of the above examples assume it's moly which is what deadens the piston slap noise. It might have been something else about the Red Line oil that quieted down my Civic's motor upon start-up. I'm not sure of another condition that would require so much plating up (metal-to-metal contact).
Bror Jace
