Schaeffer 15W-40 Blend 5779 Miles 00 Jeep Wrangler
Lake Anna, VA
Oil Gaurd Analysis
2000 Jeep Wrangler TJ
2.5L OHV I-4
Purolator PP Oil Filter 40017
Current Miles 46,473
Miles on oil 5,779
Oil was in use for about 6 months and was normally brought up to operating temp. Oil temps range from 180-220 degrees.
Onroad driving uses a K@N FIPK cone filter setup and for offroading the stock factory airbox and paper filter are used.
1st Column is last interval w M1 10W-30 3K miles
2nd Column is latest interval w Schaeffer
Copper 3 6
Iron 29 20
Chromimum 1 1
Aluminum 3 0
Lead 1 0
Moly 79 60
Phos 1041 -
Zinc 947 -
Mag 62 -
Cal 2939 -
Anti Freeze % 0 0
Fuel Dilution % 0 0
H20 % .2 .0
Silicon 5 4
Cst 9.65 14.5
SAE 30W 40W
Sulfur 35 -
Oxd % 21 11.6
Nit % 23 1.2
TBN - 7.5
Overall I'm very well pleased with how this oil performed this spring @ summer. Will be doing the same routine next summer. For fall @ winter I mixed up 3qts Schaeffer 10W-30 @ 2 1/4qts 15W-40 Blend.
Very nice! You went double the distance of the M1 run, but yet the iron is still lower, and lead wear is zero! Awesome! And the silicon levels look extremely good too, so your filter methods definitely work!
Looks great Ryan.
Good report. More evidence that using an x-30 is not the best oil for the engine. You had mileage left in it too ..but 6 months is a decent OCI.
Looks like another nice run on an xw40 oil in a Jeep motor. Definitely a solid choice for these engine conditions.
Now you've got me excited to see if my numbers were any better on my summer run of Rotella 5w40 that I sent in yesterday.
